configure twamp endpoint
configure twamp [add | delete] endpoint {vr name} ipaddress ip port udp_port
Description
This command allows you to add and delete the TWAMP endpoints.
Syntax Description
ip The endpoint IP address, either IPv4 or IPv6.
udp_port The UDP port the endpoint will listen on; range is 1025 - 65535
name An optional VR may be used; default is VR-Default.
Default
N/A.
Usage Guidelines
Use this command to add and delete the TWAMP endpoints. The user specifies the IP address and UDP port number for the endpoint. Removing the endpoint terminates all test sessions associated with the endpoint.
This command was first available in ExtremeXOS 16.1.
Platform Availability
